We bought a used Sony DCR-TRV230E for digitizing video8 and hi8 tapes after a Hitachi VM-H765LE ate a tape during rewinding and stopped playing back anything afterwards (damaged or dirty video head?)
The Sony didn't come with an original AV cable so we got a new 3.5mm to RCA cable. Unfortunately it doesnt seem to get correct stereo sound, white works but red has loud static (or the other way around).
Now...
Is this because we are not using an original Sony cable (which might be a non standard cable)?
Is the port on the camcorder dirty??
Should we use a Y Splitter to split the working audio cinch in two? Aren't we missing out on an Audio channel? Afaik all tapes contained stereo audio from the Hitachi VM-H765LE and a Sony CCD-F340E from the late 80s.
((using firewire DV is not possible as of now, because we have no device that still has firewire inputs))
edit: yep, a cable that matches Sony's pinout fixed the issue. TYVM
You need a cable that matches Sony's pinout. https://forum.videohelp.com/threads/383309-Sony-TRV-340E-replacement-RCA-cable-3-5mm
And for the video portion specifically, you should use the S-Video output instead of composite.
Sony DCR-PC10 Capture
By tarnished88 in forum Capturing and VCRReplies: 24Last Post: 4th Aug 2019, 01:23 -
SONY DCR VX 9000 - NO AUDIO on rec & play
By Promoter2000 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 20th May 2019, 12:24 -
Sony TRV-340E replacement RCA cable 3.5mm
By pavion in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 21st Apr 2017, 13:58 -
Need RCA male to video mini (8.5mm) male composite video cable
By Novice20 in forum Newbie / General discussionsReplies: 9Last Post: 11th Oct 2016, 11:00 -
Audio Issues Sony MiniDV Tape w/Sony DCR-HC46 cam
By tarana in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 6th Aug 2015, 21:35
